    Apr 2014
    Noord-Holland
    Hello everyone.
    First, sorry for my bad English. I'm officially Dutch.
    I've seen a video on YouTube from Proximity. They show the beats in the video. (example: http://youtu.be/nD-p8-k2PMM?t=4m28s)
    Can anybody explain me how I can do this? I use Final Cut Pro on Mac.
    Kind regards.
    Dylan
    Apr 2014
    Noord-Holland
    I don't mean something like this. I mean more that what Proximity have. That you see the beat in beams.
  3. This is a native after effects plugin , audio spectrum (it comes with AE, not 3rd party) . You can use a spline or mask path the "wrap" the effect - they just used a circle in that example
    Not sure if these types of plugins are available for FCP (it's more of a NLE than effects type oriented) but search terms you can look for are "audio reactive" or "beat reactive" plugins
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    HitFilm for Mac has that.
    What that is is a "Pixel Array" that has deform tools tied to different frequencies of the music. In that example, the larger "Pixel Array" is hidden by the circle, except for the edges that bump and groove to the beat or melody. Actually, the whole thing (blob) behind the circle is dancing.
    This same tool is in BorisCC, but don't know if that's on Mac.
  5. Member Cornucopia's Avatar
    Motion is Apple's equivalent to Adobe's AE. If you have FCP, you might also have Motion. Don't know if it has that move-to-waveform feature, but you should check it out.
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    You're going to need to roll yer own graphic elements too.
